2000 Chevy Cavalier check engine light
JENNIK27
Other Category problem
2000 Chevy Cavalier 4 cyl Wheel Drive Type unknown Automatic 100,00 miles
my check engine light came on and we went and got it tested the code that came up was p 1441. the cause was either a failed canister purge solenoid which we fixed, or a failed fuel tank pressure sensor. we can not get the check engine light to turn off. is there any ways we can get that light off?
Jan 12, 2008 at 8:27 AM
MERLIN2021
  • 17,250 POSTS
When you fix the problem, if you can't reset the MIL, it will eventually go out just by driving it.
Jan 12, 2008 at 8:30 AM
