2000 Chevy Cavalier no power
ROFD295
Electrical problem
2000 Chevy Cavalier Front Wheel Drive Automatic
When i turn the key, i get no response. The dash lights and radio get no power, and the car won't click or attempt to turn over. The battery is good. Headlights and clock still work. Any suggestions?
Jul 28, 2008 at 5:25 AM
MASTERTECHTIM
  • 4,750 POSTS
i would suspect a faulty ignition switch. if you can access the connector at the ignition switch make sure you have power on all red wires, if not then check for open fuses under hood or get back to me and we can track the wiring, if you have power at the red wires then check for power on the rest of them with the key on and all should have power except the yellow wire.
Jul 28, 2008 at 11:58 AM
