2000 Chevy Cavalier Moter mount
161,000 MILES • 4 CYL • 2WD • AUTOMATIC
KERRY CARTER
I can not figure out how to get the top motor mount anchor to com apart from the mounting bracket to replace it. can you help
May 24, 2008 at 3:44 AM
WILDFIREV9
  • 49 POSTS
Carefully support the engine.
There is a bolt under the air conditioning line that is barely visible. Also a nut under the plastic bracket that holds the other a/c line.
The mount that causes wobbling is underneath the front of the engine not the top one. About 8 inches long with bushings in each end.
Hope this helps, if so, give me a positive feedback.
All donations graciously accepted no matter how small.
VIC
May 25, 2008 at 5:22 PM
