2000 Chevy Cavalier losing power
DONDON433
  • 2000 CHEVROLET CAVALIER
  • 4 CYL
  • MANUAL
  • 26,900 MILES
im running out of options, so I really hope anyone out there can help me with my problem. My cars old I know and it has a lot of miles im aware. But I just had the transmission replaced, catalytic converter replaced, spark plug, and engine/ignition wires replaced. And none of it did what I wanted originally to do, which is turn off the check engine light. My check engine light will flash and I will lose power all of the sudden, and by power I mean that I will not be able to accelerate as fast as I usually am able to. It will even go down to 500 RPM's and correct itself to 1,000 RPM's after a little while of idling. This problem has only arisen after replacing the transmission, I have had no problem with it before this and ive sunk alot of money to get all of these things replaced with no solution presenting itself, I turn to you for aid, please help me with what could be wrong?
thank you so much
Wednesday, August 12th, 2009 AT 2:55 AM
MMPRINCE4000
  • 8,548 POSTS
Get the codes read at some autoparts stores for free, but a flashing light on an OBDII car is usually the convertor.
I would suggest that the trans replacement is where the problem exists. They may have broken a connector or pinched a wire bundle.
Wednesday, August 12th, 2009 AT 9:46 AM
