2000 Chevy Cavalier indicator light for coolant level
69,080 MILES • 4 CYL • FWD • MANUAL
LABEEB1
indicator light for coolant level is on, I fill the coolant but it still on. Then I change the water pump but still on, I cheek all houses and I repair the one is liking but the light still on. My engine damaged and I overall the engine and the light still on. I take temperature bulb which is located inside the engine I take it out to solve the overheat problem. The is on water circulation but engine temperature below normal (70 c normal temperature 90 c)
So PLS can you guide to solve the problem
May 17, 2010 at 1:22 PM
MMPRINCE4000
  • 8,548 POSTS
Replace coolant level sensor.
May 19, 2010 at 1:00 AM
