What does it sound like is the front drivers side (hub) wheel bearing is going out?
175,515 MILES • 4 CYL • FWD • AUTOMATIC
BILLEVANS1982
What does it sound like is the front drivers side (hub) inner sealed wheel bearing is going out??? The car at about 10mph will start making a woah, woah, woah, etc. sound everytime the front drivers side wheel turns over. Its not the axle or Cv joint as I thought because it makes no knocking noise or clicking noise when making a complete circle in a parking lot either direction. ANY INFO. would definately HELP ME OUT???????!!!!!!
May 24, 2010 at 3:57 PM
SQM
  • 6,383 POSTS
This could be a wheel bearing or a tire noise.
https://www.2carpros.com/articles/car-howling-noise
Try this, jack up the front wheels and secure it with jack stands.
Then turn the wheel by hand. If you can head the noise, then it is a bad bearing and needs to be replaced.
https://www.2carpros.com/articles/bearing-hub-replacement
Oct 27, 2021 at 7:18 AM
