2000 Chevy Cavalier idle speed
118,250 MILES • 4 CYL • 2WD • AUTOMATIC
MYGARAGE
Can my idle speed be adjusted on my 2000 cavalier? It seems to idle a little slow. I heard some mild annoying noise under the hood, especially when in gear while idling. I noticed it was the belt slapping a little, and would smooth out if I picked up the idle a little. None of the pulleys were wobbling. Would a new tensioner help, even though the tension seems good.
Thanks, J
Jul 22, 2008 at 1:13 AM
RHALL77
  • 3,361 POSTS
no idle speed can not be adjusted. check and see if your tensioner is loose, you may need a new onw. it would help the belt on it
Jul 22, 2008 at 1:19 AM
