2000 Chevy Cavalier Idle problems in park. High revs with s
LOUISFW
Engine Performance problem
2000 Chevy Cavalier 4 cyl Two Wheel Drive Automatic - miles
I have a 2.2 Cavalier and have noticed a problem with the idle. While in park the revs fluxuate, bouncing the needle, often spiking above 2000rpm. After warming the car up I put the car into drive and as I excellerated the rpm increased but I had little response. my car moved slowly forward untill i got to about 20km/h and it seemed to work fine. then i stopped at a red light and had the same problem. Any ideas?
Oct 14, 2008 at 1:12 PM
RHALL77
  • 3,361 POSTS
is the check engine light on. do you know if you have a vacuum leak.
Oct 15, 2008 at 2:13 AM
LOUISFW
no warning lights are showing, going for a system check today. hoping it might be covered in that. If not, what could the possible problems be?
Oct 15, 2008 at 8:50 AM
RHALL77
  • 3,361 POSTS
could be a number of things, get back to me with what you find out and ill try to help you
Oct 15, 2008 at 9:24 AM
