2000 Chevy Cavalier Help.
JKRAMER
Other Category problem
2000 Chevy Cavalier Wheel Drive Type unknown Automatic 100000 miles
I have a 2000 chev. cavalier it is a 2.2 4cyl motor. My problem started when i left work i noticed that my car felt funny. Usually it will shift and the rpm will go down, not this time. Everytime I would excell the rpm would go up to 2. It usually wouldnt do that after it shifts but it like lost power. I guess. It will still drive for now but i only drove that couple blocks home because i dont want to risk it. When i pulled out of work it seemed like something was leeking by the exaust. Then I went home and parked my car and noticed that there was something frozen on the ground it seemed slipery like oil? Please help!What could this be?
Nov 30, 2007 at 1:34 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e89ffd0cef="jkramer"]Other Category problem
I have a 2000 chev. cavalier it is a 2.2 4cyl motor. My problem started when i left work i noticed that my car felt funny. Usually it will shift and the rpm will go down, not this time. Everytime I would excell the rpm would go up to 2. It usually wouldnt do that after it shifts but it like lost power. I guess. It will still drive for now but i only drove that couple blocks home because i dont want to risk it. When i pulled out of work it seemed like something was leeking by the exaust. Then I went home and parked my car and noticed that there was something frozen on the ground it seemed slipery like oil? Please help!What could this be?[/quote:e89ffd0cef]
Oil doesn’t freeze up water does
Check oil and have tranny fluid checked
And may be scan the transmission for codes
Nov 30, 2007 at 3:39 PM
EZE
  • 16 POSTS
Low power + liquid discharge from tailpipe? Check the color of your radiator fluid. If it is black and oily then the head gasket may be to blame.
If so, get a compression check on your cylinders. If one or two show much lower than the others, then they could be leaking oil into the cooling system.
Dec 1, 2007 at 3:25 AM
