2000 Chevy Cavalier gas tank
TIMLUCCI
Engine Performance problem
2000 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 160km miles
i can,t seem to put gas in the tank, when i do, it just seems to fill up the tube that goes to the tank, it seems like its not getting air to allow the gas to continue to go to the tank. how do i fix this problem?
Feb 1, 2009 at 1:19 AM
BILLYMAC
  • 2,204 POSTS
hi remove the fuel tank check vent tube and if ok remove the sender see what is restricting fuel flow. billymac
Feb 1, 2009 at 11:25 PM
TIMLUCCI
i can,t seem to find the vent tube, where should this be located?
Feb 6, 2009 at 12:02 PM
BILLYMAC
  • 2,204 POSTS
the vent tube is the 3/4 inch hose runs parralel with the filler tube.some tanks have a plastic vent valve on the top near yhe sending unit billymac
Feb 6, 2009 at 12:09 PM
