2000 Chevy Cavalier fuel pump locked up
EVERSOL
2000 Chevy Cavalier
a chip is prohibiting the car from running. where is it at and how can i fix this problem
Apr 30, 2009 at 7:13 PM
JDL
  • 16,098 POSTS
Hello, I'm not sure about your problem, not enough info. If the theft system is causing a problem, that should only effect the injectors. If it is a fuel pump problem, do some testing at the fuel pump relay, under hood, power distribution center.
May 1, 2009 at 1:21 AM
