2000 Chevy Cavalier Engine cranks excessive esp when warm e
86,000 MILES • 4 CYL • FWD • AUTOMATIC
RIGGS
I have a 2000 Chevy cavalier that when the engine is cold , seems to start OK (not great but OK. But when the car has been driven a short time, and engine is warmed up -takes much longer to fire and start. (cranking is longer). At this point , it seems like the engine just barely catches and may not run smooth for a few seconds, then runs ok. Car runs OK . No stalls or anything. Any ideas what the most likely issue is?
Nov 27, 2008 at 1:26 PM
  • 75,988 POSTS
Test the fuel pressure and the engine coolant temperature sensor comeback with some results
Nov 27, 2008 at 1:40 PM
