2000 Chevy Cavalier ENGINE COOLING
ARUTHERFORD1981
Engine Cooling problem
2000 Chevy Cavalier 4 cyl Automatic 130000 miles
MY CAR IS LEAKING WATER TERRIBLY. PUTTING A GALLON IN IT AND THEN 45 MIN LATER WATER LIGHT IS ON AGAIN BUT I CANT SEEM TO FIND THE LEAK AND IT STILL HAS PRESSURE UNDER RADIATOR CAP. ANY SUGGESTIONS? DOES ANYONE HAVE A DIAGRAM OF THE COOLING SYSTEM FOR THIS CAR?
Apr 23, 2008 at 2:12 AM
GTRGILBERT541
  • 14 POSTS
[quote:27c4517e3f="arutherford1981"]Engine Cooling problem
MY CAR IS LEAKING WATER TERRIBLY. PUTTING A GALLON IN IT AND THEN 45 MIN LATER WATER LIGHT IS ON AGAIN BUT I CANT SEEM TO FIND THE LEAK AND IT STILL HAS PRESSURE UNDER RADIATOR CAP. ANY SUGGESTIONS? DOES ANYONE HAVE A DIAGRAM OF THE COOLING SYSTEM FOR THIS CAR?[/quote:27c4517e3f]
is it leaking from the heater core (Located under the dash board) if so then the water might be in the floorboard of the car
Apr 23, 2008 at 3:25 PM
ARUTHERFORD1981
[quote:8a7ec092df="Gtrgilbert541"][quote:8a7ec092df="arutherford1981"]Engine Cooling problem
MY CAR IS LEAKING WATER TERRIBLY. PUTTING A GALLON IN IT AND THEN 45 MIN LATER WATER LIGHT IS ON AGAIN BUT I CANT SEEM TO FIND THE LEAK AND IT STILL HAS PRESSURE UNDER RADIATOR CAP. ANY SUGGESTIONS? DOES ANYONE HAVE A DIAGRAM OF THE COOLING SYSTEM FOR THIS CAR?[/quote:8a7ec092df]
is it leaking from the heater core (Located under the dash board) if so then the water might be in the floorboard of the car[/quote:8a7ec092df]
THERE IS NO WATER IN THE FLOORBOARD I CHECKED THAT YESTERDAY. I ALSO CHANGED RADIATOR CAP AND THAT DIDNT HELP. UNDER CAR THERE IS WATER RUNNING DOWN SIDE OF CAR. IM SO CONFUSED. ANY SUGGESTIONS?
Apr 24, 2008 at 1:11 AM
DISCOSTU24000
  • 37 POSTS
Most of the cooling system is pretty visible by looking under the hood. The only thing out of sight is the water pump, its under the exhaust manifold. If you can get under the vehicle you'll be able to see it. If it's leaking that much coolant you should be able to easily see it flowing out of the pump, or possibly the lower radiator hose. Also check the heater hoses while you're down there.
Apr 24, 2008 at 2:22 AM
