2000 Chevy Cavalier Digital Odometer Malfunction
SINGZ4J
Electrical problem
2000 Chevy Cavalier 4 cyl Two Wheel Drive Automatic ? miles
A few months back the Digital Odometer started working intermittently, it would lose brightness in parts then some lines in the numbers or appear to 'stick' at the same number but if you tapped the dash or pushed the trip meter button it would straighten out for a while then start doing it again. A few weeks ago it cut out working completely and now there appears to be no lights behind it at all and it is black. All other dashboard gauges and lights are working with no issues. Any suggestions and possible cost of repair? Any help is appreciated.
Mar 6, 2009 at 3:31 AM
MMPRINCE4000
  • 8,548 POSTS
If odometer is only problem, you will most likely have to replace the entire assy.
Try a junk yard, see if you can find a good used one.
Mar 11, 2009 at 1:27 AM
