2000 Chevy Cavalier code p0301 being thrown
2000 CHEVROLET CAVALIER
MISTYE
Engine Performance problem
2000 Chevy Cavalier 4 cyl Automatic 130000 miles
we are getting a code p0301 (Cylinder #1 Misfire)
after we've replaced the plugs & wires. we've reset the check engine light to have it just come on again.
not sure what to try next.
any help would be great. thanks
Aug 9, 2008 at 9:06 AM
Check the compression and injector for no.1
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Aug 9, 2008 at 9:26 AM
MISTYE
could it be the coil pack?
Aug 9, 2008 at 10:06 AM
Switch coil packs around and see what happens to the misfire at no.1
Aug 9, 2008 at 11:08 AM
MISTYE
fixed it. it was the coil.
thanks for your advise
Aug 9, 2008 at 1:26 PM
You're very welcome sir and thanks for the donation its badly needed to keep us in operation to help people in need.
Aug 9, 2008 at 1:56 PM
