2000 Chevy Cavalier Changing the Guage cluster
115,000 MILES • 4 CYL • FWD • MANUAL
DOUBLECLUTCH1000
I would like to change the guage cluster on my car to after market guages. any ideas on how to do that.
Feb 22, 2009 at 6:51 AM
MMPRINCE4000
  • 8,548 POSTS
You would have to remove old cluster and fabricate a panel (generally aluminum) to fit. Cut holes in panel and use existing harness wiring to the extent you can. In other words the new gauges may require different senders.
Having said all that, you must be carefull not to interfere with sensors that send information to PCM, and you would have to get the odometer mileage set to correct number, otherwise it will flag an error on a carfax report if you ever sell it.
Feb 22, 2009 at 11:28 PM
