2000 Chevy Cavalier Car problem
150,000 MILES • 4 CYL • 2WD • MANUAL
JJHART06
Hi, my car recently shut off while I was at a stop light, it would crank over but not start up to run. Replaced the fuel pump and fuel filter brand new but that wasn't the problem, can you tell me what may be the problem?
Jul 19, 2010 at 3:36 PM
  • 75,988 POSTS
Cranks but no start condition-do below to determine whether it's fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 19, 2010 at 3:44 PM
JJHART06
It was the crank sensor, its running great now. =)
Jul 25, 2010 at 11:10 AM
