2000 Chevy Cavalier AC Compressor
159,000 MILES • 4 CYL • 2WD • AUTOMATIC
RYANSMITHSD
I recently discovered my AC compressor going bad- it is a one belt serpintine system that powers everything. Can I get a smaller belt and bypass the Compressor to keep the car running? I know I probably won't have a working AC but it is nice 70's here in SoCal. If you know what the name of the belt or the part number and how much I can expect a shop to do it that would help as well. Thanks
Nov 30, 2009 at 3:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you can purchase a bypass drive belt. just call local auto part store and let them know what you're needing. should be around $100 labor and part at local shop.
Nov 30, 2009 at 4:44 PM
RYANSMITHSD
[quote:558473a407="bluelightnin6"]yes you can purchase a bypass drive belt. just call local auto part store and let them know what you're needing. should be around $100 labor and part at local shop.[/quote:558473a407]
The Drive Belt or 1990 - 2002 Chevy Cavalier 2.2L AC A/C Bypass Pulley seen here?
Nov 30, 2009 at 5:34 PM
