The brakes locking up could mean that it's time to replace the rear shoes either due to being worn or the linings being hardened. Or you could have bad wheel cylinders inwhich you will see when you do the rear shoes.
As far as the abs coming on, you will have to have that looked at and the code retrieved from the abs system, it could just be a wheel speed sensor.
SPONSORED LINKS
Friday, March 12th, 2010 AT 4:33 PM
