2000 Chevy Cavalier
2000 CHEVROLET CAVALIER
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANTONIO TABITA
engine hesitates when i push down on gas pedal
Jun 27, 2010 at 5:25 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 27, 2010 at 11:48 AM
