2000 Chevy Cavalier
TESSIE5
  • 2000 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 121,000 MILES
I have a loud noise from the front end we have changed the wheel bearings and left cv joint still there any idea what it might be when you turn the wheel to the right the noise goes away
Friday, September 25th, 2009 AT 2:10 PM
MMPRINCE4000
  • 8,548 POSTS
Try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Saturday, September 26th, 2009 AT 7:42 AM
