2000 Chevy Cavalier
VTGREENBLUNT
  • 2000 CHEVROLET CAVALIER
2000 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
where are the fuel filters on a cavalier I am haveing problems with it and need to check it
Tuesday, February 3rd, 2009 AT 10:11 AM
JDL
  • 16,098 POSTS
My info shows the filter is located on the rear crossmember, underneath, you need to look.
The filter shows to have a threaded fitting on one end and a quick connect fitting on the other end. I have used needle nose pliers on that type fitting. It's probably best to use the proper tool. I believe the autostores sell them.
Make sure there is no pressure on the system, before you take anything loose.
Friday, February 8th, 2019 AT 6:28 PM
