My 2000,2.2l,156000miles cavalier start overheating, the mechanic change the thermostat,check the fan,took the air bubles out still did not resolve the problem .I change the thermostat 3 times to 3 differents mechanics,And it just can stop overheating.Plus I notice on freeway(pass65MpH)the temperature goes down below the normal and I can get no heat in the cabin, in city(under65mph) it's overheat pass normal, the heat came in the cabin but not enough.the fan switch in the cabin work only when turn on high. Any Idea what is wrong?? :
Feb 3, 2007 at 11:52 AM
