1999 Chevy Cavalier Upper Engine Mount
1999 CHEVROLET CAVALIER
55,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS81964
I have removed the engine mount. It is leaking fluid. I bought an insert at autozone. How do i remove the insert to put in the new one. The guys at autozone believe it is glued on. I have drilled the holes uunderneath and i cant get the rubber portion out.
Any suggestions will be appreciated
Mar 30, 2010 at 7:41 PM
MMPRINCE4000
  • 8,548 POSTS
Rubber bushings can be burnt out using a propane torch.
Wear eye and full body protection, do it outside. The bushing can "pop" out when heated.
Mar 31, 2010 at 8:10 AM
