1999 Chevy Cavalier Transmission feels like it's slipping
10,900 MILES • 4 CYL • FWD • AUTOMATIC
BENV
Car has the 4 speed auto with traction control.
On rare occasions, shifting to drive either from a stand still or from reverse(I always stop the car fully before shifting), the car will shudder like the parking brake is on(it's not) then takes a long time shifting from 1st to second. I get around this by manually shifting to first then up through the gears. No warning lights come on and techs haven't found any codes. A tranny fluid change at 100k miles made no difference. Not a serious problem as engine, brakes and trans all have worked fine for years. It's more a nuisance, really.
Feb 18, 2009 at 12:30 PM
MMPRINCE4000
  • 8,548 POSTS
Other than checking the cable connection to the trans. (look for loose brackets, loose bolts, missing retainers), you will have to take to trans shop for diagnosis.
Feb 19, 2009 at 12:07 AM
