1999 Chevy Cavalier Thermostat
C_A_BECKWITH
Heater problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
What is the location of the thermostat on my car and how hard is it to get to? Is it an easy fix? Thanks
Dec 9, 2008 at 5:47 PM
MMPRINCE4000
  • 8,548 POSTS
Follow the upper hose to the engine, intake manifold or head, you should see a housing that contains the thermostat.
You have to partially drain the coolant, remove housing, replace thermostat and gasket.
Dec 9, 2008 at 11:57 PM
