1999 Chevy Cavalier SERPENTINE BELT
IBYTE
  • 5 POSTS
Electrical problem
1999 Chevy Cavalier 4 cyl Automatic 78000 miles
Old belt shredded on edge put on new belt within seconds new belt shredded same place outer edge not motor side
thank you
Sep 3, 2010 at 7:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If none of the pulleys are locked up, then one or more pulleys are not all lined up properly ( out of alignment ) or your tensioner is bad.
Sep 3, 2010 at 9:31 AM
IBYTE
  • 5 POSTS
[quote:085b1decb2="bluelightnin6"]If none of the pulleys are locked up, then one or more pulleys are not all lined up properly ( out of alignment ) or your tensioner is bad.[/quote:085b1decb2]
I only have one belt
Sep 3, 2010 at 10:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes i know...if one of the pulleys (power steering, a/c etc...) is misaligned it will shred the belt..
Sep 3, 2010 at 10:28 AM
IBYTE
  • 5 POSTS
we think it may be the air conditioner pulley, does this mean I have to replace the entire ac unit?
thanks again
Sep 3, 2010 at 10:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no, you can get the a/c pulley only for probably $10 - $15 at a junk yard or $25 - $30 brand new.
Sep 3, 2010 at 11:30 AM
IBYTE
  • 5 POSTS
Thanks, can I replace the pulley even if the ac pulley bearings are shot, because the ac is not working
Sep 3, 2010 at 12:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if the bearings are bad then the pulley is probably frozen up? pulley is actually not at fault then, that would indeed be the compressor ..
Sep 3, 2010 at 12:43 PM
IBYTE
  • 5 POSTS
good to know.. I wouldn't have guessed the compressor would shred a belt
Sep 3, 2010 at 12:58 PM
