1999 Chevy Cavalier Puzzling - throttle not responsive, car
1999 CHEVROLET CAVALIER
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTT14450
My Cavalier usually runs fine. However, at times it gets in a mode where the following occurs:
-Tranny shifts extremely hard, rattling the car.
-Tranny won't shift during normal acceleration unless I let off the throttle a bit
-The throttle has a delay of about 1-2 seconds in responsiveness
-Usually, this mode is accompanied by the "ETS off" light illuminating on the dash
The vehicle will go back to normal operation (shifting and throttling fine) after turning off the engine or letting it sit a while.
My first thought would be to replace the shift solenoid, but would that explain the sluggish responsiveness of the throttle? Without a check engine light on, how am I able to further diagnose?
Thanks,
Scott
Aug 13, 2010 at 1:07 AM
MMPRINCE4000
  • 8,548 POSTS
PCM may still have an error code in it. Most low end scanners will only scan "P" powertrain codes. ABS and traction control set a "C" chassis code.
If you have acces to ABS scanner, try scanning it to check for chassis codes.
Sounds like the PCM is putting transmission into "limp" mode.
I would certainly try scanning before replacing shift solenoids.
Aug 13, 2010 at 1:52 AM
SCOTT14450
Thanks for the quick post. Can I use the ABS scanner when the vehicle is operating normally, or do I need to wait until it is in 'limp' mode?
Aug 13, 2010 at 8:02 AM
MMPRINCE4000
  • 8,548 POSTS
ABS code are stored in memory like powertrain codes.
Aug 14, 2010 at 1:13 AM
