1999 Chevy Cavalier Lights flickering
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
SILENTFIRE117
Hey , when i am driving at night my head lights will flicker , when i open my door my interior lights will flicker , and when i have my radio up high my radio will flicker , but it only happens to my headlights when i step on the accelerator , what could this be
Apr 4, 2010 at 10:34 AM
INTERNETMECHANIC
  • 700 POSTS
Check the battery and all connections. Sounds like the charging system is fluctuating. Is this problem something new?
Apr 5, 2010 at 3:10 AM
SILENTFIRE117
well i just bought my first car its a used car , i had my battery and my alternator checked there both fine , ive been told its a bad ground , what do u mean by my charging system is fluctuating ?
Apr 5, 2010 at 12:23 PM
INTERNETMECHANIC
  • 700 POSTS
Engine rpms can effect alternator output. Less rpms dimmer lites, more rpms, brighter lites or flicker. If you have a digital multimeter you can test, when the problem is ongoing. Goodluck with the car.
Apr 6, 2010 at 2:29 AM
