1999 Chevy Cavalier Light noise
49,000 MILES • 4 CYL • FWD • AUTOMATIC
EDDIEB325
  • 7 POSTS
Hi, My cavalier has been a very good car, ive had it about 5 months and a recently i have heard a noise like "when your drinking the last bit of something through a straw." that light kkkk noise. It sounds like its coming from the engine. I know its not my brakes, it does it when im sitting still. It does it the most when i first crank it and then almost everytime I accelerate. I don't know if it could be a clogged fuel filter or not, no idea. I have had my fuel pump replaced and i have my oil and oil filter changed every 3,000 miles. It is a 2.2 liter if that helps any. If you could help in any way I would really appreciate it.
Eddie
Apr 10, 2008 at 5:21 AM
RHALL77
  • 3,361 POSTS
does it misfire or anything? is your cooling system full or antifreeze?
Apr 10, 2008 at 5:50 AM
EDDIEB325
  • 7 POSTS
Yes, actaully a lot. In the morning when I first crank it, it fires right on up no problem, and its chilly outside. I dont know if its a coincidence but when it gets warm during the day it acts like it doesnt want to crank, it turns over but i have to crank it for like 4 or 5 secs. It should crank the same everytime.
About the anti-freeze, idk. It runs cool, it nevers gets hot.
Apr 10, 2008 at 7:37 AM
RHALL77
  • 3,361 POSTS
is the anitfreeze full, does it run rough when it starts?
Apr 10, 2008 at 8:08 AM
EDDIEB325
  • 7 POSTS
yes its at the right level, no it runs smooth. I think i got the misfire thing wrong. Its just when i crank it, it doesnt crank right, other than that little noise and it not cranking the first time everytime, it runs very smooth. no lights are on or anything. It doesnt skip or bounce , anything.
Im not sure if its anything with my ignition or not.
Also when I have to do a long crank its almost as if im having to flood it to get it cranked, thats always what happens, i can smell it, outside the car.
Im just trying to pin-point whats wrong so I don't spend a lot of money.
Apr 10, 2008 at 8:29 AM
RHALL77
  • 3,361 POSTS
does it act like it is starving for fuel? can you check the fuel pressure?
Apr 11, 2008 at 12:10 AM
EDDIEB325
  • 7 POSTS
thats exactly what I was thinking. I don't know how. I was planning on getn it checked sometime soon.
would this be related to my fuel injectors at all?
Apr 11, 2008 at 3:30 AM
RHALL77
  • 3,361 POSTS
it has pretty much everything to deal with them
Apr 11, 2008 at 4:08 AM
EDDIEB325
  • 7 POSTS
ya, so do you think that the little noise and it not cranking everytime like it should is the fuel injectors? They might be failing, my car is 9 yrs old.
Apr 11, 2008 at 4:13 AM
RHALL77
  • 3,361 POSTS
i would suggest having it looked at at your local shop. they can install the proper tools figure out what it is doing. the injectors may also be bleeding down.
Apr 11, 2008 at 4:31 AM
EDDIEB325
  • 7 POSTS
what does bleeding down mean?
Apr 11, 2008 at 4:45 AM
RHALL77
  • 3,361 POSTS
it means that they are not sealing and leaking fuel into the cylinder. they are not holding fuel pressure.
Apr 11, 2008 at 4:52 AM
EDDIEB325
  • 7 POSTS
Sounds right, Thank you so much for taking time to answer my questions. I really appreciate it. I'll have my injectors looked at and hopefully thats the problem.
Apr 12, 2008 at 2:45 AM
