1999 Chevy Cavalier Ignition Lock Cylinder
102,000 MILES • 4 CYL • FWD • AUTOMATIC
DUDASRA
The car died (SHUT OFF), according to the person I loaned it to the other day, and would not start again.
I pulled the starter checked it and the solenoid, also checked the Starting Relay, and fouynd them to be fully operational. I then checked the Neutral Safety Switch and found it to be good. Then I tried JIGGLING the Ignition Key while I turned it to start the car. Walla! The car started after about ten or so wiggles.
Next I pulled the Ignition Lock Cylinder and noticed it had a small amount of play between the cylinder and the housing as I turned the key. Due to the High Cost of the replacement part (Due to the Anti-theft Chip) plus the shop Fee to reprogram the PROM could you advise me what I could do temporarily until I can raise the $300.00 plus for the parts and Computer Reprogram Fee. Could flushing out the cylinder with JB Blaster or WD-40 poosibly clean out any chips or wear shavings that might be causing an obstruction which prohibits the cr from starting.
I REALLY NEED your help ASAP!!!!!!
Thank You In advance! I've read your site infrequently over the last few months and appreciate your professional responses.
Sincerely,
Ron
Mar 30, 2010 at 7:57 AM
MMPRINCE4000
  • 8,548 POSTS
I would use a spray electronics cleaner. Also call a locksmith, they may be cheaper.
Mar 31, 2010 at 1:12 AM
