1999 Chevy Cavalier Hitting gas does nothing.
CARNEWB87
  • 1999 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 96,000 MILES
The car will start but shakes horribly. When I hit the gas I get no response from the engine. When the problem started it was only a delayed response when I hit the gas. Any ideas would be a big help thanks.
Monday, July 7th, 2008 AT 11:23 AM
RHALL77
  • 3,361 POSTS
Sounds like no fuel did you check fuel pressure. Also check to see if there is spark at all the spark plugs. Also check to see if there is injector pulse if everything else is ok.
Tuesday, July 8th, 2008 AT 12:59 PM
