1999 Chevy Cavalier Engine sputters on hills and blows out
1999 CHEVROLET CAVALIER
145,000 MILES • 4 CYL • FWD • AUTOMATIC
BOND1418RW
I have a 1999 cavalier with a 2.2 liter engine front wheel drive. Currently the engine blows out black smoke, and really goes at it on hills. It has the error code number P0171 is on the check engine light. Currently I have replaced the, bank 1 and bank 2 o2 sensor with both bosche manufactured ones. IAT sensor, the map sensor, the coolant temperature sensor which has the car running some better. But still hesitates and stumbles while driving, and of course the black smoke.
Apr 24, 2009 at 5:24 AM
JERRYGOODWRENCH
  • 77 POSTS
have you checked the convertor?? Could be partially blocked. check the spark plugs .Are they black?? Does the engine have low vacuumn. This would be an indication of convertor problem. Let me know..
Apr 24, 2009 at 10:31 AM
BOND1418RW
Just put a new converter on it yesterday at a garage.. As far as the vacuum goes, I need to buy a vacuum checker. I hear no air leaks on it which doesn't mean much tho.
Apr 24, 2009 at 12:53 PM
JERRYGOODWRENCH
  • 77 POSTS
what about the EGR valve.Carefully unbolt it and inspect the pintle is it corroded ,black soot. carefully clean and check gasket on egr . check vacuumn hose tht runs to egr. Process of elimation at this point..
Apr 24, 2009 at 11:05 PM
BOND1418RW
Muaahahaha lets winch the car up a trree and drop it jk. On a more serious note I replaced the throttle position sensor i figured what the heck lol........ NOw to find what else it can be...... I am about ready to take it to the garage. Thanks for your Help!
Apr 25, 2009 at 1:14 PM
