1999 Chevy Cavalier CV Shaft
110,000 MILES • 4 CYL • FWD • AUTOMATIC
TOLLIVER42
  • 7 POSTS
I have some questions about my CV shaft i can't seem to get it to come out of the transmission. I've tried to pry it out and pull it out but nothing really is seeming to work. I was wondering if yall had any better ideas for me?
Oct 5, 2009 at 9:37 AM
MMPRINCE4000
  • 8,548 POSTS
It should pop out, the best tool to use is a slide hammer with a "C" shaped attachment, you may be able to rent from an autoparts store.
Oct 7, 2009 at 2:14 AM
TOLLIVER42
  • 7 POSTS
alright thanks ill give it a try and hopefully it works...cause i dont know what else to do if this dont work..
Oct 7, 2009 at 5:12 AM
MMPRINCE4000
  • 8,548 POSTS
CV shaft is held in with small "C" clip and can sometimes get stuck.
Oct 8, 2009 at 3:00 AM
TOLLIVER42
  • 7 POSTS
alright if itis stuck how would i get the C unstuck without breaking it or messing it up?
Oct 8, 2009 at 5:22 AM
MMPRINCE4000
  • 8,548 POSTS
Try to rent the slide hammer tool, it is the easiest way. If not available, then ask a shop for the cost to remove and repair.
Oct 9, 2009 at 1:51 AM
TOLLIVER42
  • 7 POSTS
alright thank you for your help.
Oct 9, 2009 at 4:55 AM
MMPRINCE4000
  • 8,548 POSTS
Thanks for using 2carpros.
Oct 10, 2009 at 1:05 AM
