1999 Chevy Cavalier Check Engine Codes
130,000 MILES • 4 CYL • FWD • AUTOMATIC
PAIGE YORE
We had a code that indicated "Cylinder Head Temperature Guage" and took it to be replaced. Instead, they put in a "Coolant Temperature Sensor" saying that it was the same thing. The coolant temp never changes now and the check engine light is on again and STAYS on but with a new code--> 0118 UIF which reads as "Engine Coolant Temperature High Input". Also, the car shut itself off when started- while warming up. Please explain whether or not cylinder head temp guage and coolant temp sensor are same or NOT and then what this newest code means before we spend any more money on something that won't help. When the car is driven: either warm or cold/different speeds - at times it seems to shudder (sometimes worse than others) as though it's going to die but then seems fine.
My college age daughter is driving this and I am concerned for her safety but can't afford to be strung along with incorrect repairs either.
Jan 1, 2009 at 3:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The cylinder head temperature gauge is in fact the coolant temperature sensor.
The code means that for some reason the PCM (Powertrain Control Module) is seeing a high input from the ECT (Engine Coolant Temperature) sensor. That could be the sensor itself (not likely since you have a new one), a wiring problem, thermostat or a PCM problem. You may want to have the repair shop recheck there work to ensure they have all the wires connected correctly.. However, the most likely problem is the thermostat.
Hope this helps..
Thanks for using 2carpros.com!
Jan 1, 2009 at 3:27 PM
