HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Brakes
Bleed - Flush
1999 Chevy Cavalier brakes
DFOSR1948
MEMBER
1999 CHEVROLET CAVALIER
4 CYL
FWD
AUTOMATIC
100,000 MILES
Put new master cyclinder and metal brake lines on and can't bleed brakes no brake fluid out of three wheels just left frount
Sunday, August 24th, 2008 AT 8:43 PM
RHALL77
MECHANIC
Check the openings on the bleeders, they may be plugged. If they are, replace them
Sunday, August 24th, 2008 AT 9:30 PM
BLACKOP555
MECHANIC
When yo push on the pedal with the engine off does pedal stiffen up or stay pretty soft?
Which ones have no fluid? Did problem just start out of the blue? Check lights on? Engine, abs, brake?
Sunday, August 24th, 2008 AT 10:00 PM
Please
login
or
register
to post a reply.
Related Bleed - Flush Content
Bleeding Brakes
While Bleeding The Brakes I Tripped The Valve In The Master Cylinder And Now Can Only Get Brake Fluid Out Of Right Rear And Left Front. In A...
Asked by
tbird62
1996
CHEVROLET CAVALIER
VIDEO
Bleed and Flush Your Brake System Correctly
Instructional repair video
GUIDE
Brake System Flush
An automotive brake system flush is similar to a standard brake system bleed except for all of the brake fluid is flushed out of the brake system components such as the...
Bleeding The Breaks
How Do I Bleed The Breaks On A 95 Chevy Cavalier
Asked by
voigt1
1 ANSWER
CHEVROLET CAVALIER
1999 Chevy Cavalier Brake Caliper Bolt
While Putting My Barke Caliper Back On I Accidently Put 1 One Starting Wrong And Now I Need To Re-tap The Hole, What It The Size?
Asked by
cadplater
1999
CHEVROLET CAVALIER
Emergency Brake
Hey I Got A 93 Z24 With A 3.1 5spd I Need The Drivers Side Part For The Emergency Brake I Was Wondering If Both The Drivers Sde And...
Asked by
jakebernard
CHEVROLET CAVALIER
1997 Chevrolet Cavalier Brake Drums
Just Got New Shoes And Drums For My Cavalier Put Everything On As It Should Turned Adjusters In All The Way Got The Proper Size Drums Just...
Asked by
codym7247
4 IMAGES
1997
CHEVROLET CAVALIER
VIEW MORE
Bleed your ABS Brake System Correctly Video
Brake System Flush
