1999 Chevy Cavalier Bad lifter: can I disable that cylinder
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
GE1234
I have what appears to be a collapsed lifter - there's nearly 1/8" of play in the rocker arm. The car runs OK, but it's pretty noisy. Given the general condition & age of the car, we're going to get another one, rather than pull the head and replace the lifter.
In the meantime, we still need a car to get around.
2 questions:
1. Is there any great downside to just driving it as it is?
2. Would it be better (or even OK) to just disable that cylinder - remove both rocker arms & push rods, and disconnect the injector?
Thanks
Mar 31, 2010 at 11:30 AM
CRZYDRVR
  • 432 POSTS
The car was meant to run on all cylinders, I would not "dis able" that by any means. But if you insist, give it a try and let us know how it works out for you.
Apr 2, 2010 at 1:42 PM
GE1234
[quote:cbbb9ccfa9="crzydrvr"]... But if you insist, give it a try and let us know how it works out for you.[/quote:cbbb9ccfa9]
Other ppl had a more ... disparaging, let's say ... take on that scheme. Among other things, that the lifter would likely get dislocated, without the pushrod holding it down. Oh well.
Plan B of the moment is to try using a 'lash cap' between the valve stem and the rocker arm - sort of, treat it like a solid lifter.
G
Apr 2, 2010 at 3:34 PM
