1999 Chevy Cavalier Acceleration Hesitation
90,000 MILES • 4 CYL • FWD • AUTOMATIC
DRWSTR102200
My Cavalier is hesitating when accelerating out of idle and when in drive trying to acclerate up to speed. Im thinking its a misfiring problem with the injectors but trying to narrow it down more. Any response would be highly appreciated. Thanks.
Jun 23, 2010 at 3:48 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 23, 2010 at 4:07 PM
