1999 Chevy Cavalier
BOONEY410
Electrical problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
i put a new starter in it but it wont turn over just the dash lights come on i dont think it is the starter
May 23, 2010 at 7:11 AM
INTERNETMECHANIC
  • 700 POSTS
Make sure the battery has a full charge and battery connections are clean and tight on both ends. Did you try cranking in neutral? The purple wire at the starter solenoid S terminal should be hot with the key in the crank position. If it isn't hot, backtrack the circuit. From ignition switch to neutral switch to starter solenoid s terminal. It may not be either switch, could be wiring circuit?
May 23, 2010 at 7:44 AM
