car hesitates when i accelerate aft its been sitting awhile and only happens from 1 to 3 min aft car is moving then its o.k.
Aug 24, 2010 at 9:39 AM
WRENCHTECH
✓Experienced Mechanic
That could be a problem with the Mass air Flow Sensor. You can try unplugging it and see if that changes anything. It will set a code when you do that so you will have to get it cleared after.
