1999 Chevy Cavalier
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
BADDAZ
Once my car warms up the thermastat will rise until it reaches the max then start to ease it way back down. it will then rise and fall depending on my speed or if the heat/Ac is running
Feb 16, 2010 at 9:24 AM
SHARPKAT79
  • 17 POSTS
if the temp is changing by what your rpm is it could be a bad water pump. are you losing any coolent if so is it alot
Feb 25, 2010 at 9:01 AM
