1999 Chevy Cavalier
WELLWOOD03
Steering problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
HOW DO I CHANGE MY FRONT WHEELE BEARING ON DRIVER SIDE
Aug 23, 2009 at 2:30 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_99_cavalier_bearing_1.jpg
Hello, if possible, I loosen the hub nut first, with the tire on the ground. Don't let the caliper hang by the hose, use a piece of wire. I don't recall the size of the hub nut, on some models it is metric. A good set of tools helps alot. Make sure to safely support the vehicle.
Aug 23, 2009 at 3:00 AM
