1999 Cavalier-heater not working/after sensor replacement
CHEVY1999GRACE
A few days ago I brought my 1999 automatic cavalier into the dealership because my check engine light was on. They said it needed a new coolant sensor and harness. Had them replaced, but now after 3 days, I went to put the heat on in my car and it won't work and the car is now making some type of noise. Noise is like when you put cards on bicycle spokes. Do you think this problem is related to the recent repairs? I don't want to go back and have them tell me that I need another $500.00 worth of repairs. I really hate being "mechanically" challenged and taken advantage of over car repairs. Thanks.
The check engine light is not coming on, the check gauges light is now on. The noise started after the heater broke and is not heard if it's turned off. Air does blow out, but it is cold.This morning when I went out there is some type of fluid that has leaked out all over the driveway towards the right side of the car. I can't tell what color the fluid is, but it is "oily" to the touch.
I will get the car back to the dealer for it to be checked, but I am hesitant only because everytime we've brought the car in for repairs, something else inevitably goes wrong with it within a week of us getting back from the shop.
Nov 10, 2007 at 8:51 AM
SERVICE WRITER
  • 9,123 POSTS
Don't feel bad about being mechanically challenged. tere are many techs that start becoming that way from not staying current with technology.
Let's first try to find the problem, then see if it is logical to be related.
BTW, there is nothing wrong with calling the shop and asking them to recheck their work, We have had to make good on our boo-boos..it happens.
So, Lets back up a minute.
Is the check engine light stlll out, I assume it is.
The noise you are hearing only happens when the blower motor is on? Your description sounds like a blower motor problem at the moment if this is what is happening. When you say you don't get heat, do you mean no air is blowing out the vents?
Nov 10, 2007 at 9:22 PM
