1998 Chevy Cavalier Winding Noise when gas pressed
ELLIEPOOO
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Problem started a few days ago, when I start the car it kind of hums. When i press the gas it makes this winding noise that is somewhat high pitched , when I slow down or take my foot off the gas the winding seems to slow down until i come to a stop and the winding stops. I have no idea what this could be but would like an idea to see if it needs to go somewhere or something easy i can take care of
Dec 18, 2008 at 6:40 AM
RHALL77
  • 3,361 POSTS
you may be low on power steering fluid. have you check to see if you have any leaks.
Dec 18, 2008 at 8:18 AM
ELLIEPOOO
Nope checked the power steering, ive had that problem before. this is a little different because its when the gas is pressed and i dont even need to be moving for the noise to start
Dec 18, 2008 at 8:30 AM
RHALL77
  • 3,361 POSTS
can you remove the belt and see if it is a pulley that maybe locking up and getting a bad bearing
Dec 18, 2008 at 8:38 AM
ELLIEPOOO
hahaa nope, but I will be taking it to a shop so i guess they can. I was just trying to see if it would be something super easy and save me time and $$
Dec 18, 2008 at 8:41 AM
RHALL77
  • 3,361 POSTS
let me know what you find out
ELLIEPOOO
So I took my car to the shop , turns out the car has been only running off the battery and needs a new alternator. was reading at 12 volts? Mechanic could not believe I've been able to start the car or able to drive it for the last week and a half. I have not been able to start it late at night or early in the morning when its too cold but should be able to start it one more time tomorrow morning to bring it to the shop
Dec 22, 2008 at 11:24 AM
