1998 Chevy Cavalier warning lights
142,000 MILES • 4 CYL • 2WD • MANUAL
AKUHNY1
I just got this car. Day one the low fluid light came on. The only fluid down was the ps fluid, cap was missing. I replace cap and put fluid in. The next day the check engine light and abs light came on. The pads and rotors were gone, so I replaced them. Abs light and check engine lights still on. Any suggestions?
Jun 16, 2008 at 10:58 PM
BMRFIXIT
  • 19,053 POSTS
With out a scanner you can check gas cap and make sure it on and tight ,check for vacuum leaks ,
check fuses and check the wiring harness by the wheel sensors
I suggests getting it scanned for codes as that will pin point troubled area
Jun 16, 2008 at 11:20 PM
