1998 Chevy Cavalier warning lights
AKUHNY1
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • MANUAL
  • 142,000 MILES
I just got this car. Day one the low fluid light came on. The only fluid down was the ps fluid, cap was missing. I replace cap and put fluid in. The next day the check engine light and abs light came on. The pads and rotors were gone, so I replaced them. Abs light and check engine lights still on. Any suggestions?
Tuesday, June 17th, 2008 AT 5:58 AM
BMRFIXIT
  • 19,053 POSTS
With out a scanner you can check gas cap and make sure it on and tight, check for vacuum leaks,
check fuses and check the wiring harness by the wheel sensors
I suggests getting it scanned for codes as that will pin point troubled area
Tuesday, June 17th, 2008 AT 6:20 AM
