1998 Chevy Cavalier tranny noise
FAQBUSH
Transmission problem
1998 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
Then tranny makes a growling sound when going and shifts fine and normal. I took apart passenger side wheel and brakes and turn axle by hand and hear a rubbing sound like a chain or spring every one revolution. please help.what could it be and must I take tranny apart
Nov 7, 2009 at 7:15 PM
MMPRINCE4000
  • 8,548 POSTS
I would check the wheel bearings, CV shaft boots for leaks, control arm bushings and ball joints first.
If indeed a trans problem, then output shaft bearings in trans are suspect.
Nov 9, 2009 at 1:37 AM
