1998 Chevy Cavalier Theft system?
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANAM427
Driving down the the road my car completly died. Engine stalled and would not restart. All electrical systems are still working fine. It cranks but will not start. I dont think its the fiuel pump because i can still hear it prime when i turn the key just before trying to start it. Do you think it could be the theft system? If so how to i go about resetting it and fixing it?
Oct 21, 2008 at 6:24 AM
RHALL77
  • 3,361 POSTS
could be the theft system is the light on. are you sure you have gas and your fuel level sender isnt bad.
Oct 21, 2008 at 9:18 AM
ADRIAN_H
I have the same problem as anam427. The car runs great all summer and during very cold winter months but every spring and summer the car won't start, but will turn over. it does sometimes happen while driving. I have replaced the fuel pump, bypassed the theft system, and replaced the ignition module and coil packs to try to fix the problem, but still have problems. The fuel pump is working and there is spark. The check engine light only comes on during these times. Today it started and seemed way out of time, pinging and idling rough, then died, during this time the gauges twitched and jumped and the check engine light flickered. Is my computer bad? How can I tell, otherwise any ideas?
Oct 27, 2008 at 4:02 AM
RHALL77
  • 3,361 POSTS
what code do you have. and what do you mean you bypassed the security system
Oct 27, 2008 at 4:49 AM
