1998 Chevy Cavalier Stuck in high gear
1998 CHEVROLET CAVALIER
KAREN3LAWN
Transmission problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
The transmission is stuck in high gear even when shifting through the gears manually. Are there basic things to check through first before giving up?
Thanks
Feb 18, 2010 at 6:35 AM
2CARPRO JACK
  • 11,533 POSTS
Honestly it doesnt sound good.Check fluid level first.If check engine light is on, you can have the PCM scanned to see if it stored any trans related codes.
Feb 19, 2010 at 12:00 AM
