1998 Chevy Cavalier Speedometer broken after replacing alte
156,000 MILES • 4 CYL • FWD • MANUAL
KCARTER05
1998 Chevrolet Cavalier RS. alernator died, took out the battery and alternator to have them checked. battery was fine, but had to replace the alternator. after doing so, i put the battery back in and started the car, engine worked fine but now my speedometer is stuck on the highest mph. all other gauges work fine..
Aug 9, 2010 at 10:13 AM
MMPRINCE4000
  • 8,548 POSTS
Try tapping the front of gauge to see if it will release.
If not, check the VSS connector on trans, you may have hit it when changing alt.
Aug 10, 2010 at 1:49 AM
